跳转到主内容
加入维修社区 - 创建账户
代号为 A34 的第六代 Maxima 仅在美国、加拿大和墨西哥销售。该车型在 2003 年北美国际车展上以 2004 年款的身份正式亮相。
Won't start. Just clicks when I turn the key.
I drove 2005 nissan maxima se to the store when I came out it wouldn't start tried jumping no start, Just make a click noise from what sounds from the dash of the passenger side at first but after we got the new battery it now sounds like the click sound is coming from center under the hood. But all lights power on heater window work radio all work head lights come on and do deem while trying to turn it over. got new battery no start checked ground wires good. From what I can tell the fuses and relays seem to be working the battery reads at 12V but drops just a bit when I turn over the key. Now it was struggling to start but when I turn off the key then back on it start fine but it got me to the store it didnt get me home. The motor turns so it not locked up. But I did notice there was oil that leaked all over the wires that are between the battery and the motor once the air intake was removed did wipe them down but nothing changed I've google it, youtube it, and ask who I could bout it locally but it all leads to dead ends. Please any advice is got to better then what I have now. I just bought it uses drove it about 2 weeks then it died. Thank anyone with advice in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@melefrain have you checked the starter? Could be a bad solenoid.
完成的
Yes new starter new battery new spark plugs
完成的
添加一条评论
2个答案
最有帮助的答案
could be a few things
- low/bad battery
- bad starter
- bad ignition
- power connection issue from ignition to starter
- power connection issue from battery to ignition
- anti-theft device malfunction (of some kind)
I would test all these first
这个答案有帮助吗?
得分 1
2条评论:
Help I have same problem I replaced battery an crankshaft sensor help I need car only one I have
完成的
@trish15578 give us the exact year, model, symptoms of your problem, and the troubleshooting you’ve already tried
完成的
添加一条评论
The One thing that you mentioned about the oil leak could be the cause if it leaked on your starter. The easiest thing to do is possible is take it to an Auto Zone and have it tested, it's free. Especially if it's fine till you try to turn it over if the oil impeding the circuit it can't get past the starter to crank, it will click at the solenoid.
Here's a good video that covers all the things you can do to get to the bottom of the problem
https://youtu.be/s6OXK1XztI0?si=rm90P31Z...
Good luck🤞
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Melissa Lawson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,492
