跳转到主内容
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
450 个问题 查看全部
Boots then Shut down
I have an iPad Air 2 which is starts to boot then turns off. After screen keeps flashing with Apple Logo.
When I check PP_GPU line shos a Short (multimeter beeps) checked resistance for that line which is 20 Ohm
Also Not charging, USB not recognised when plug it to the Mac and can not put it into DFU Mode
Tristar has been changed to a known good one.
Battery Has been changed to a known good one
Any Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
hello Peter,
As a mature electronics engineer, you know that the tolerance to low resistance signaling increases depending on the multimeter you have. It depends on the settings of the more expensive or the quality of the cheaper device. The indication of 20 ohms does not mean a short circuit in the line, but a line with reduced resistance (because the circuit is designed to operate with low voltage, less than 1V, used in processors and high level controllers.
There are many reasons why the boot loader resets. Unfortunately, you won't find out without trying to restore your device and record the log from that attempt (it's one of the repair options for iPad). Restore the usb connection with the computer as first. Depending on the control program (it may be iTunes) find out how to find and save the log from the process. If you cannot interpret the results, speak up - I will help with it.
  • regards,
这个答案有帮助吗?
得分 0
添加一条评论
This is the thing… If I plug it into my mac it does not recognise it.
I try to put it into DFU mode But nothing happen.
Im an iOS Technician but I never seen something like this before
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Peter Hupuczi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 38
