跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Stuck in bootloop after replacing battery
So replacing the battery from ifixit went like this. After replacing the battery the phone was stuck in boot loop. I tried a few possible solutions but whitout any luck. Luckily i did not throw old battery away so i replace the new one with old one. Phone did turn on and it is working. I switch it again to double check if there was bad conection but same story as before so i switch it back to old battery and again it is working. What do you think went wrong ?
Update (12/19/2020)
Here are pictures
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You would need to rule out the battery first. But since this is an iPhone 8 it could be the battery connector on the logic board. If the old battery had a slightly bigger connector the new battery connector might not be making solid contact with the pins. Have a look under some magnification at the connector if it looks fine you will need to organise a replacement battery.
这个答案有帮助吗?
得分 1
2条评论:
Connectors looks the same. Only thing beside bootloop that i get is graphics that show for connecting phone with pc. And at the end i get nothing after i pick update or restore from iTunes. Also i notice today iphone does not close completely with the new battery and battery alon looks like it is loosely wrapped in some paper in comparison to original battery.
完成的
@interista Post some images of the battery.
完成的
添加一条评论
添加你的答案
matej 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 395
