跳转到主内容
Repair information for the Logitech K750 wireless solar keyboard. First available on Amazon in 2011. Model numbers: 920-002912 (Windows), 920-003472 (Mac).
13 个问题 查看全部
How are the plastic parts under the spacebar arranged?
I cleaned under the spacebar but can’t properly snap it back into place. There are four black plastic rectangles that must be positioned correctly for it to snap back. I’ve tried several arrangements for the rectangles but can’t find the correct one. Logitech won’t publish a simple picture of the proper configuration. Is anyone else able to show or describe the proper configuration of these small plastic rectangles under the spacebar?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
In all this time I hope you’ve been able to solve it, answering for anyone to come, but let me know, I could lift one and send pics!
I have two of them, I’ve done it once with one after liquid spill (not mine, JIC) to give it a good clean and if IRRC there’s one way the plastic tabs fall flat and other where they stick up. In that position the space bar should click right in. I don’t remember if I fitted the tabs on the keyboard or in the key first, only one of those worked. Try dissembling another key to check, as I remember small keys being similar but easier.
Cheers!
这个答案有帮助吗?
得分 0
添加一条评论
Thanks for this. I’d still like to fix this, and haven’t yet been able to do it (bought replacement). Pics would help. I don’t think other keys are the same as space bar on this, but if you say so…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jerry West 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 397
