跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
memory replacement ios 14
Hello I want to replace my battery and upgrade my memory from 16gb to 64 gb but I am having doubts because of ios 14 I haven't done the update to ios 14 however I don't to change the battery and memory then do the update and everything to go bad..My question is the problem whit changing non original parts only why the newer iPhone or it could affect my old 6s also thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
How do you plan on upgrading the memory?
完成的
@imicrosoldering whit a new chip
完成的
添加一条评论
1个答案
已选择的解决方案
You will need to read the syscfg data from the NAND that’s on the phone and write it to your new NAND I gather you have a programmer? After you solder the new NAND on you will have to do a full restore with whatever IOS apple is signing at the time so there is no need to update now. Just change the battery.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Boris Yanev 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 93
