跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—在2017年6月上市,这台入门级MacBook Pro保留了它的实体功能键(相对于OLED Touch Bar)。
Battery not charging after replacement
This weekend I replaced the battery in my MacBook Pro with a new ifixit battery. The MacBook had worked fine until recently, when it suddenly stated that the battery was not charging and needed replacing. Following on from this, it ran exceptionally slowly and would not boot at all at times.
I have replaced with a new battery, and it now turns on just fine (after an OS re-install), but is still saying that the battery is not charging. It now lists the following:
  • Fully charged: No
  • Charging: No
  • Full Charge Capacity (mAh): 4698
  • State of Charge (%): 1
  • Cycle Count: 0
Could it be the new battery has an issue? Any advice would be kindly received.
Update - CoconutBattery image as requested -
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
While you have some on the needed information I need to see a bit more to figure this out.
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
由完成的
Hi Dan, have downloaded the app and added the image - hope this was what you needed to see
由完成的
添加一条评论
2个答案
已选择的解决方案
Update:
Followed up with ifixit support, who believe the replacement battery was faulty, so kindly sent out a new kit.
Have installed it today, and the mac is now working and charging properly :)
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Could you have damaged the battery data cable or not fully secure it? I would start there
If that is in good order, I fear the charging logic needs to be investigated on the main logic board.
这个答案有帮助吗?
得分 2
7条评论:
Hi Dan,
I will attempt disconnect and reconnect the battery cable. Do not believe it was damaged during disassembly or re-assembly, but it could be the cable itself as this does not come with the replacement battery (needed to use the old cable), and this is exactly the same error I had prior to changing the battery (could be the old battery was not actually the problem?)
I presume the screenshot shows that the new battery itself is absoutely fine?
If it is the cable, I will order a new one and see if this resolves. Out of interest, what are the next steps to investigating the charging logic on the main logic board?
由完成的
@Richard Crampton - The CoconutBattery results is perplexing!
Some of the data which comes from the onboard micro controller within the battery (the little logic board attached to it) is finding its way to the SMC services (Like the temp 19.3℃). But for some reason the current charge is zero!
I would start off replacing the cable and then see where you are. If that didn't alter things then its something within the logic board charging logic.
由完成的
@danj thanks for the feedback. Interestingly, CoconutBattery is also reporting that the new battery is 1,281 days old - would that be correct? Not sure if the batteries fixit sell as part of the kit are refurbished (which would make sense), or if this could be related...
由完成的
@Richard Crampton - iFixit does not sell used or refurbished batteries!
Did you replace the cable?
由完成的
@danj My apologies, I did not mean to cause any offense! I am waiting on the replacement cable to arrive. The question was more around the fact that CoconutBattery is showing the new battery as follows (as per my screenshot):
Manufacturer: DSY
Manufacture date: 2017-06-12
Age: 1,281 days
Will see if that changes at all with the new cable once it arrives.
由完成的
显示更多的2条评论
添加一条评论
添加你的答案
Richard Crampton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 33
总计 12,049
