New PC build, no beep, no display, fans spin.
Im fairly new to building PCs but I have been watching countless videos on youtube to help me begin.
First of all, after building the PC, I hooked it up to a monitor and started it up.
It powers on with lights from my GPU, AIO, and MOBO, after a second, the aio cooler flickers a few times and fans go full speed. The gpu fans eventually stop and the aio cooler no longer has lights. I have tried everything, reseating RAM, cables, removing GPU/other non boot essential components. I have gotten to the point where its just the RAM, CPU, MOBO and PSU connected and it still has the same issue. I have also tried using a different psu and it continues to have that problem.
I have seen countless guides and forum posts saying that its the CPU or MOBO thats the issue but I do not have a spare of either to replace/test.
I am suspecting that the mobo is the problem because of shipping damages, the box was a bit rough and the plastic encasing the mobo had holes due to the pcb solder joints.
Please help me identify the problem :)
2条评论
Hi
What are the specs of the build i.e. make and model number of the motherboard, CPU, RAM, GPU and PSU.
Have you verified that the motherboard supports the CPU and the RAM by checking the motherboard makers support website?
Does the CPU have an integrated GPU since it doesn't seem to pass POST with a GPU card either
Is the PSU sufficient for the minimum requirements of the GPU as per the GPU makers recommendations e.g. does the GPU need a separate power feed?
You say "no beeps" but have you got a system speaker connected to the motherboard?
由 jayeff 完成的
Specs -
Asus Z390 Prime
I7-9900k
2070 Super
Corsair C16 (2x8gb)
Evga 600W bronze
Yes I have check that it's compatible
The CPU doesn't but the Mobo said it has integrated.
Yes the GPU uses 1 8 pin and 1 6 pin
Yes I didn't hear any beeps
由 Eduardo Kho Jr. 完成的
