跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
LCD identical to iPhone 4
I got informed by my iphone part supplier that the iphone 4S LCD is identical with iphone 4 (Verizon) LCD. Not so sure, can anyone confirm?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
5个答案
最有帮助的答案
I have seen a picture that the one of the notches isnt the same but thats only one picture ive seen so far
这个答案有帮助吗?
得分 1
添加一条评论
they are different. Just do an image search of the cdma, gsm and 4s iphone screens and you'll see the bracket is different. Just saw this a little bit ago. A co-worker had his all of 12 hours before it got dropped and smashed! Bummer!
这个答案有帮助吗?
得分 1
添加一条评论
I had the same thing happen and I'm replacing the front panel as I type this reply.
https://www.etechparts.com/
They have most of the 4S parts already, but the digitizer and screen is a bit pricy, $117. I ordered yesterday and got the parts today for 12 shipping.
这个答案有帮助吗?
得分 0
添加一条评论
Here is a guide to fit the CDMA screen which has different mounting screw positions than both the 4 GSM and the 4S. The guide is located @ Modmyi it has nice large images and has easy to understand steps..
Install a CDMA iPhone 4 screen on an iPhone 4S
这个答案有帮助吗?
得分 0
添加一条评论
Just swap the bezel from your old frame. The connections are the same.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anh Vo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,008
