跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
475 个问题 查看全部
FaceID Trouble after screen replacement
I recently replaced the screen on my iPhone 11. I’ve replaced iPhone screens from iPhone 4 through 11 so I’m not new to this. I knew that there were issues with parts being paired to boards so knew their may be some trouble ahead. I purchased the screen on eBay. The seller said that True Tone works but I would get the “not genuine” message in settings.
I replaced the screen and all went well. Everything worked EXCEPT True Tone. I didn’t even get the message of not having a genuine display. The seller offered to take the screen back but I also ordered a Xr screen for my niece and didn’t want to deal with the back and forth. I went ahead and ordered a JC-V1 for both screens to regain True Tone.
I got the JC in today and went ahead and performed on my phone. Got True Tone back however, now FaceID doesn’t work. It pops up in Settings and I can start the process but every time it eventually says it isn’t available and try again later. It tells me to move the phone higher and reposition my face and eventually gives the message of try again later.
I don’t think I damaged any cable. Any input would be great.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The dot projector has become faulty. There is not much you can do unless you have the right equipment and experience as you need to read the data from the original and write it to the new one along with soldering it to the flex.
这个答案有帮助吗?
得分 1
2条评论:
Thank you for the reply. How does the dot projector become faulty.? I know anything can happen at anytime but let me make sure I was clear. FaceID was working for the 4 days I was waiting for the “True Tone Fix” device to come in. I just popped the screen back off, wrote the OG data from the OG screen to the new screen and popped it back on. Stopped working from there.
完成的
@jd_guthrie Not sure how it gets damaged. There is some info on it here. iPhone XS Max Face ID Not Working Fixed - Dot Projector Repair Have you tried updating the phone after you used the JC-V1?
完成的
添加一条评论
hello, I had the same problem if you solved it please answer me
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jared Guthrie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,302
