跳转到主内容
加入维修社区 - 创建账户
2017 年 6 月,Apple 更新了其 13 英寸 MacBook Air,配备了更新的 Broadwell Intel Core i5 处理器,性能和电池续航时间均略有提升。
Random shutoffs/service battery error despite new battery installed
Hi all!
I have a 2017 Macbook Air - the original battery was running out of juice, so I had it replaced at an Apple store (out of warranty). The "Service Battery" warning is gone in the Finder, as well as under System Information, and coconut battery indicates good battery health with full capacity.
However, once a day, while plugged into a new adapter and with a fully charged battery, the display will shut off. Interestingly, I see the indicator on the adapter quickly change from green to orange, then back to green. It doesn't seem to fully shut off - when I press the power button, it takes about 25-30 seconds for the sleep display to turn back on, and all the programs are running like before. This is the same issue I was having with the old battery, except that one of course had lowered capacity and the service battery warning.
The issue has persisted despite resetting the SMC and PRAM, and doing a "recalibration" with a full discharge. While there is no service battery indicator in the Finder or System Information, when running diagnostics, it does indicate a service battery error with the reference code PPT004. I've tried a couple of other potential fixes from this forum as a Hail Mary (resetting PRAM x 3/hearing 3+ chimes, turning off thunderbolt ethernet), but the problem has continued.
If anyone might have advice, it would be much appreciated. Thanks so much!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
由完成的
@danj Thank you so much Dan! I've attached screenshots from CoconutBattery and system information. The battery status has looked top notch since the replacement in CoconutBattery, but of course the service battery error still shows up when running Diagnostics on start-up.
由完成的
添加一条评论
1个答案
已选择的解决方案
The battery micro-controller firmware has a problem! You’ll need to return the battery to where you bought it to get a replacement.
这个答案有帮助吗?
得分 1
2条评论:
@danj thank you Dan! If you have a moment, just for my education, were you able to tell there was a firmware problem just from the screenshots? My novice eyes didn't see anything off in those reports.
The reason I ask is that I had the identical issue (random shutoffs while plugged in, with adapter light flashing green->orange->green) with the old battery as well, and I'm surprised to see the same issue with both batteries.
由完成的
The SMC logic on the main logic board talks to the battery. The signal to the SMC from the micro controller is not getting to SMC.
SMC appears to be working correctly which was the other possibility.
You still have one other issue here with is the MagSafe Charger! Many people are using knockoffs these are bad news! Make sure you got yours directly from Apple, not Amazon or eBay or non-dealer rack.
● Don't Replace Your MacBook Charger With a Cheap Knockoff
● OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
● Lacking safety features, cheap MacBook chargers create big sparks
● FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
The risk here is a defective ground can damage your system if you are using anything else which is powered by AC.
由完成的
添加一条评论
添加你的答案
Alex Han 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 806
