跳转到主内容
Repair guides for the Samsung Galaxy J5 (2015), released June 2015.
41 个问题 查看全部
Samsung galaxy J5 screen flickering
hello.
I have bought this Samsung Galaxy J5 2015.
it works for a minute, then the screen starts flickering with random colors and its glitching and then it turns off, but the phone is still on. (as seen in photos).
what do I do?
thanks for your help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi,
You could try to mirror the screen to determine if it is a display problem or perhaps a systemboard problem, before you open up the phone.
If the mirrored image is OK then more than likely it is a display problem or display connection problem, although it still could be a systemboard problem but this is less likely.
The phone will need to be opened and the display flex cable connection to the systemboard checked to ensure that it is a secure. If it appears to be OK then the display will have to be temporarily replaced and the phone checked to see if it is now OK.
Here’s a teardown video that may be of some help.
Replacement displays are available online. Just search for Galaxy J5 2015 LCD Digitizer Display Replacement to get results for suppliers.
这个答案有帮助吗?
得分 5
添加一条评论
添加你的答案
Kapy 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 25
总计 304
