跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Change NAND when reader can't extract info
Hi!
I have an iPhone 8 with a corrupt nand ic. I have removed the nand and plugged it in my JC Pro1000S. The reader detects nand but is stuck at “loading… 100%”
Is there anyway to extrect the info i need to nand from the board so i manually can type it to the new IC?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@refectio Maybe know? :D
完成的
添加一条评论
1个答案
已选择的解决方案
Yes there is but not with the JC pro you are using.
1.       The Magico box. This will read SYSCFG from a dead NAND. Than use your JC Pro to write it.
2.       Order a GSX report for your phone. This can be costly and can take some time.
这个答案有帮助吗?
得分 2
4条评论:
Thanks! But seems like Magico does not support iPhone 8?
Thanks for answer!
完成的
@mexii It must be just up to the 7. I don’t suppose you can get hold of an IP box mini although that requires the NAND to still be on the phone but it can read the bottom layer which is where the SYSCFG is. I am not sure if it will read a non-readable one though. I had this problem a couple of years ago and gambled on the sim tray IMEI to be correct. I ordered a GSX report which gave me the rest of the info to write to a new NAND.
完成的
@imicrosoldering Thanks! Seems like GSX Report is my way to go this time. Do you know what MLB and MD are?
Thanks for your help!
完成的
@mexii MLB is main logic board I don’t know about MD but could be modem. I am not sure which serial number MLB would be it is not the phones serial number. I have an example from my SYSCFG file.
syscfg add SrNm C6KVD3C7JC5R
syscfg add MLB# C7H748200CUHPJ9A9
完成的
添加一条评论
添加你的答案
Johan M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 372
