跳转到主内容
The Dell Latitude E6500 laptop PC was released in August 2008. The Latitude has a 15.4 inch screen with a 500 GB hard drive
How do I get this working
my dell isn’t starting up i think it is the battery that doesn’t make it start
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @xxthenottakenxx ,
Does it start with the charger connected to it, you didn't say?
What lights are showing when the charger is connected or when you try to start it and are they flashing or steady?
完成的
添加一条评论
1个答案
If you doubt it’s the battery interfered the computer's startup process. Try removing the battery to run the laptop from just the AC power. If it works, you may have a defective battery that needs replacing.
If nothing fixed the problem, this indicates that the problem may be on other components of the laptop, at least you can do some basic troublshooting.
https://www.minitool.com/backup-tips/del...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
The not taken 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 135
