跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Why can't I activate my iPhone 8?
The phone has had some pretty serious damage. Busted back cracked screen and the home button doesn't work. It has been restored with iTunes and does not have find my iPhone turned on. It always says no service, even when a sim card is inserted. It searches when turned on but never finds service. I just wanted to use it in my shop because it still connects to wifi. Is there any way to activate it? It failed via iTunes and via wifi.
I appreciate you reading my question!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You have a faulty baseband CPU or baseband PMU that is why you cannot activate it. You can test this with 3uTools or on the touchpad by typing (*#06#) if baseband is all right it will bring up your IMEI number. This would be a costly repair. If the baseband CPU has an internal short there will be no fix.
 If you wanted to use it in your shop with just Wi-Fi you will need to jailbreak it.
这个答案有帮助吗?
得分 2
3条评论:
So how how would I go about jailbreaking it? I haven't done anything about that since the first ipod touch.
It doesn't show an imei in the info section or when you dail that in the keypad.
完成的
@mer_rs I have never tried jailbreaking an iPhone. “Apple Tech 752” has a lot of videos on you tube about it.
完成的
Much appreciated!
完成的
添加一条评论
添加你的答案
Mason Roy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 462
