跳转到主内容
The Fossil Q Marshal Gen 2 Smartwatch was released in 2016. Primary functions include GPS, fitness, notification alerts, and the ability to tell time.
14 个问题 查看全部
The charging ring fell off my smartwatch.
I am getting a Fossil Q Explorer Gen 3, and it’s being sold at a low cost because the charging ring has fallen off the back (apparently a common problem with watches that have charging rings).
The ring is still intact and fits into the groove. I don’t know how charging rings work exactly, but is it possible to use hot glue to stick it back in? If so, what glue brands are conductive/ water and sweat proof? Would glue affect the waterproofness or safety of the watch?
And as an additional (possibly stupid) question, could I solder the charging ring back in? Solder is conductive after all and wouldn’t allow the charging ring to come off even if it was covered in sweat. Or would the heat damage the watch body?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Have you had it made yet? ? Solved yourself or taken away for repair? I have the same problem.
这个答案有帮助吗?
得分 0
1条评论:
I was told (not by a Fossil rep) that any old superglue would do, so I used loctite. Unfortunately I didn't position the ring correctly, so you need to keep that in mind or else it's never coming back out. Or you can send it back to Fossil and it seems they'll give you a replacement, provided you meet their conditions. Hope that helps.
完成的
添加一条评论
https://www.reddit.com/r/WearOS/comments...
Alteco super glue but you need to make sure you don’t glue the bump on the back
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Geraldine Cheung 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 24
过去 30 天: 129
总计 4,686
