跳转到主内容
Only one key (delete) doesn't work on my Mac. Any tips?
Delete Key isn’t working. Should I replace the full keyboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Don't make mistakes! ;-}
What happened? Can you give us a bit more... How about a picture if that helps.
完成的
I didn't open it yet. I just know that key is like dead. Doesn't
send sinal. Eg: It doesn't turn on the backlit
完成的
[image|2276058] @danj that is my key clip type. Where can I find the wire you told?
完成的
@edimar - Sorry was busy today. What happens when you press the rubber nipple in the middle? Does the Delete key work then using the viewer to see it.
完成的
Hi @danj, thanks for the help!! It doesnt work when pressing it too
完成的
添加一条评论
2个答案
最有帮助的答案
Open your system preferences keyboard control panel, check the Show keyboard viewer in Menu bar so you can open the viewer. Using the viewer, see if the delete key functions there.
Update (12/08/2020)
I think you can get away with just replacing the rubber dome piece Type-G Silicone Dome - Standard
这个答案有帮助吗?
得分 1
3条评论:
It doesn't work. Any other key get a darker background when pressed...
It works when clicked on viewer but does not physically
完成的
Unlike the standard keys the longer base keys use a wire to align the press more centered. I'm suspecting the wire jumped the clip point so you'll need to pop off the keycap to then moved it back. Review this page to figure out which type you have click on the image to dig down Unibody MacBook Pro KeyCaps
完成的
Sorry I was thinking of the bigger keys. No wire on this key.
完成的
添加一条评论
You will need New keyword
这个答案有帮助吗?
得分 0
1条评论:
Do I need a full keyboard replacement?
完成的
添加一条评论
添加你的答案
Edimar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 34
总计 8,989
