跳转到主内容
How do I fix a sunken in lock button?
Hello everyone! My girlfriend recently came across an annoying problem with an iPod Touch I gave her. The lock button appears to have sunken in, and is now flush with the frame of the iPod. She told me that it was sticky before it finally sunk. I know how to take the front panel off the iPod, and I have tried to pry the switch out without opening it. Do I need a new switch? Or do I need to pop it open and push the switch up?
Sorry for the wall of text. Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
If it's like the 2nd gen touch then the switch is held in place by two screws. You'll have to take the top circuit board off to get at those screws. You may even have to take out the LCD panel if there's not enough room. If one of those screws did come out it's a good idea to get the ipod open ASAP as that screw could cause an electrical bridge and short out a board.
here's how to get that top board out.
这个答案有帮助吗?
得分 1
1条评论:
Ok, thanks alot. I'll get on this as soon as I possibly can. I'll keep you posted on the results
完成的
添加一条评论
remove the glass by prying it up with a plastic tool, 4 clicks on left and right, one on top, 2 on bottom, careful not to crack it, before lifting it up, unplug the cable in the top left. you can unscrew it from there and adjust it. then screw it back in
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 6,350
