跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Upgrading SSD of MacBook Pro Early 2015 13"
Hi Folks!
Hope you all are staying safe and fine.
I have a MacBook Pro Early 2015 13.3" (i5, 2.7GHZ Processor) with 8 GB RAM and 256 GB Flash Storage.
Though I have cleaned up my Mac and installed Catalina, I still feel my device is slow in booting and slow in Read/Write and other performances.
Since we know that the RAM cannot be upgraded and have to manage with 8 GB, will there be any difference in performance when I upgrade the SSD to 1 TB (Possibly planning to install Crucial or WD).
Your suggestions will be of great help guys.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
添加一条评论
1个答案
最有帮助的答案
If your SSD is very full it will slow down your mac. If you put a 1tb in you could partition off a small part for extended memory.
这个答案有帮助吗?
得分 1
2条评论:
my SSD is 256 GB and it is not full.
188 GB Free of 256.
完成的
@Avinash™ Kumar - Then you likely have a M.2 SSD fitted with an adapter which is not able to work very well. This is a common issue on using these adapters/SSD combo's.
完成的
添加一条评论
添加你的答案
Avinash™ Kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 235
