跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Home Button not working
Perhaps someone can help me. I just disassembled mine and got to the very end. I can't see anything wrong with my home button. The Apple tech said it was just some prongs that needed to be bent back, but I don't see anything like the prongs. My home button stopped functioning completely. Should I just replace the entire home button and ribbon, or should I replace something else, or are there really a couple of prongs that need to be bent back?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thanks. That worked. Extremely time-consuming and by far the most difficult task I've ever completed, but it works perfectly.
完成的
添加一条评论
1个答案
已选择的解决方案
I just replaced mine, there are no prongs. It's the entire home button and ribbon that need replacing. It's all one piece.
这个答案有帮助吗?
得分 1
1条评论:
Thanks. That worked. Extremely time-consuming and by far the most difficult task I've ever completed, but it works perfectly. (I commented on this above, before it was an answer, so it shows up twice.)
完成的
添加一条评论
添加你的答案
jkgarrett17 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 836
