跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Front camera randomly working
Hi everyone.
Today I got a second hand iPhone 6S,
It was listed as “battery and front camera not working”
I changed the battery. It made the phone turn on
Then I check the camera. As described it’s not working.
So I replace the front sensors assembly.
And now it’s still not working. I even tried swapping the entire screen and sensors with one from another 6S’s.
At one point of unplugging and checking the connection, I reconnected the cameras and the battery, then turned on the phone, and it worked !
But then I screwed back everything in place, it stop working again.
I suspect a faulty connection but what do you think ?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like a bad connection to me. Look carefully at the FPC connectors on both the logic board and the ribbon cable and look for any bent or missing pins. If the connectors look good make sure they make a good solid connection when you plug it in again.
Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Théo Lcss 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 27
