跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
How to tell if heatsink needs replacing?
Is the heatsink supposed to sound like it has liquid in it when you shake it? On a recent tear down of my imac to put new paste on I shook the heatsink and couldn’t hear any sloshing etc. I’ve read that the heatsink has liquid in it that can sometimes leak out and wonder if a new unit would have detectable liquid in it by sound.
Hope that makes sense.
Much thx
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I’ve never heard any sloshing ;-}
There is a few ways to tell if the heat sink is failing even before you open the system!
Monitoring the thermal sensors using a good monitoring app like TG Pro I monitor the core temps and the Heatpipe outgoing air or Heatsink Proximity looking at the delta difference between them no more than 20℃. By far this is the easiest and works across all systems.
A good inferred viewer will show you the heat map between the heat sink to the fin area. That works on a MacBook Pro’s but you can’t effectively see the iMac’s as the CPU/GPU’s are on the back side.
If you have the heat sink out I use a scale to measure the weight of the heatsink comparing to a second (exact same model and both clean)
Looking at the logic board and the heat tube you might see a white power or staining if you suspect the system is over heating. Inspecting the heat pipe you might see a pinhole.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 100
