跳转到主内容
MacBook Air: Could Water Damage Be Repairable?
Hi all,
TL;DR up front: I think my SMC chip is bad but am not sure. How can I tell if it’s a bad chip on my logic board or something easier to repair?
A while ago I spilled water onto my MacBook Air (Early 2014) keyboard, and impatiently tried to power it back on without waiting very long (stupid, I know). It started to boot but eventually died. I then was more patient, and dried it out for four days. Still no luck, but after cleaning some obvious corrosion off the IO board with IPA there were signs of life, so I replaced the IO board and cable with one I got from this site and the computer booted.
As happy as this made me, the system runs really slowly. The kernel task takes up a large percentage of CPU, which is likely because the fan does not spin at all (Macs Fan Control reports 0RPM despite trying to set it to full blast). All of the temperatures seem reasonable (<50C, checked using Macs Fan Control). I have tried resetting NVRAM and SMC, but no luck there. I was able to get it to run at full speed using “SMC bypass” or whatever the debug mode enabled by holding the power button and connecting the power adapter is called, but without a fan I realize I run the risk of damage.
When I run diagnostics, (holding D while booting), I get the following error codes:
  • PFM006 (There may be an issue with the SMC)
  • PPF004 (There may be an issue with the fan)
  • PPF003 (Doesn’t explicitly say, but I’m guessing this is also the fan)
  • PPN001 (There may be an issue with the power management system)
At this point, I think I’m looking at a bad SMC chip which I don’t have the tools to replace without a whole new logic board. Does that seem accurate? Is there anything else I can check/do before I seek out a for-parts device online? That seems cheaper (but admittedly riskier) than repairing my logic board or purchasing a new one.
Thanks,
Andrew
EDIT: Here is a picture of the SMC chip and surrounding area
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yup, you have an SMC issue. You’ll need to take the logic board out to inspect it as its on the other side right were the keyboard tends to leaks when its splashed MacBook Air 13" Early 2014 Logic Board Replacement The purple marked chip is the SMC chip:
Look for corrosion around the chip, If you see something take a nice sharp picture so we can see things as well 在已经存在的问题里加入图片
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
MacBook Air 13" Early 2014 Logic Board图片
指南
难度:
困难
50 minutes - 1 hour
这个答案有帮助吗?
得分 0
3条评论:
Thanks Dan! I added an image as requested.
完成的
@adbotelho - Sadly I do see corrosion damage so it does look like your SMC chip and the surrounding components got the worse of it ;-{
Some one with deep micro soldering skills and access to the needed parts should be able to bring the system back to life! Or, you could just replace the logic board.
完成的
Thanks for the input. I’ll be on the lookout for something cheap I can salvage the logic board from.
完成的
添加一条评论
添加你的答案
Andrew Botelho 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 141
