跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
iPhone SE 1st gen not restoring
Hi there, I have an iPhone SE 1st generation which does nothing unless I plug it in and put it into dfu mode. Without doing this the phone appears dead. It comes up with the option to reset and I do so but the device gets stuck on waiting for iPhone and eventually error 4013 will appear. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
There is a problem with communications between the NAND to the CPU. It is most likely a faulty NAND. There are also other possibilities that could cause this problem including charge port, battery, Tristar IC and charge cable but it is likely to be the NAND.
It might be time for an upgrade as this would be a costly repair.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
rileytucker2211 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 97
