跳转到主内容
The XPS 13 9370 is a 13.3 inch ultra lightweight portable laptop top created by Dell in 2018.
Screen replacement without changing top assembly
Hello, can the screen be replaced without changing the entire top assembly? I mean, can you replace jus tthe lcd screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
I’ve recently replaced a display on an inspiron 13. I forget the specific model. If it’s anything like that which it looks like it should be. Yes you can. You’ll have to remove the display from the main body of the laptop. After that you should be able to use a pry tool to carefully separate the halves of the display housing. after that it’s just a few screws to remove the display. If you do this yourself just triple check and triple check again that you’ve ordered the proper display.
这个答案有帮助吗?
得分 0
添加一条评论
David, this is a long shot but where did you end up purchasing your screen from? I am in search of a 13.3" FHD screen replacement for my XPS 9370 and I can't find a reputable source.
I have the non-touch variant for reference.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Gutierrez Armayor 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 19
总计 854
