跳转到主内容
华为2019年4月的旗舰机,搭载6.47寸FHD+OLED屏,屏下指纹,40MP主摄,加8MP远景镜头和全新的耳机扬声器技术,型号VOG_-L29和VOG-L09
Why won’t the power button work after a screen replacement?
So I had a Huawei P30 Pro come into the shop for the first time for a simple screen replacement.
I replaced the screen and the device seemed to functioned perfectly only to find the power button would not respond and/or turn on or off the device.
I know for a fact it was working before. Still with no solution a second P30 Pro came into our shop a week later for a screen replacement again. I just completed the screen repair only to find it has the identical issue with the power button!!!
anyone have any solutions or come across this before!? I’m out of ideas.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Took me hours to figure this out - the cable from the buttons runs to between the motherboard and the frame, you just need to re-screw down the motherboard and circuit will be complete, buttons will start working again.
这个答案有帮助吗?
得分 1
添加一条评论
While still off, hold the power button down for 10-20 seconds, let go, reconnect battery and power the phone on. This works for many
这个答案有帮助吗?
得分 0
1条评论:
Ah this didn’t work.
I have unplugged and reply the battery multiple times. The only way to “turn it on” is to plug it into the power
完成的
添加一条评论
Did you resolve this? I'm having the same problem!
这个答案有帮助吗?
得分 0
添加一条评论
Me too same problem. Please suggestio s. How I check is screen good or problem of mobo?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josiah 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 2,289
