跳转到主内容
Apple's sixth-generation smartwatch, with optional cellular connectivity, released September 18, 2020. Model A2376, 44 mm.
47 个问题 查看全部
Is the 6 the same as the SE in terms of repairs?
I have an SE with a cracked screen and I only see tear downs/repairs for the 6 and not the SE. I wanted to know if they were the same so I could order a screen. I’ve been trying to google it/search Reddit/and apple’s site as well. I know that the protective cases can fit either, I just don’t know if that is enough of a similarity to expect the insides are the same as well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
If you’re looking for a screen replacement guide for the SE, then go to 苹果手表 SE 屏幕更换
But if you’re only looking for a glass replacement then there’s a video on YT for a glass only replacement (it’s a bit old but it’s basically the same for the newer apple watches) https://youtu.be/PZYWzsB_yfA
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Byky 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 399
