跳转到主内容
加入维修社区 - 创建账户
Battery won't charge - reports 0mA/h remaining, Fully Charged: Yes
I went on holidays, unplugged my Late 2011 13” Macbook pro from the wall, but forgot to shut it down. On return, plugging in the power adapter, green light comes on straight away. It will not charge the battery. Status of the charger is “Not charging”
Report from “System Information” is below.
Perhaps the most notable information is that it reports charge remaining as 0mAH, whilst simultaneously reporting Fully Charged: Yes.
Clearly that is not correct.
The battery is relatively new, replaced last year, with a battery purchased here on ifixit.
Obviously the system is able to communicate with the battery, but it will not charge.
Have tried SMC And PRAM reset.
I’m out of ideas.
Why would it be reporting “Fully Charged” when it is flat as a tack?
Battery Information:
  Model Information:
  Serial Number: C01514309YEF90MA4
  Manufacturer: Newer Tech
  Device Name: A1322
  Pack Lot Code: 3230
  PCB Lot Code: 30db
  Firmware Version: ddae
  Hardware Revision: dac2
  Cell Revision: 2b39
  Charge Information:
  Charge Remaining (mAh): 0
  Fully Charged: Yes
  Charging: No
  Full Charge Capacity (mAh): 6142
  Health Information:
  Cycle Count: 41
  Condition: Normal
  Battery Installed: Yes
  Amperage (mA): 0
  Voltage (mV): 7873
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You could see if resetting the SMC is able to fix things.
Otherwise, I’m thinking you killed the battery, time for a new one sorry ;-{
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephen Hill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 549
