跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Display Issue iPhone 8
Hi,
Has anybody seen an iPhone behave like this? Please view photos.
I have changed 3 original screens but it doesn’t seen to be a screen issue.
If it is a Logic board issue where should I look and what should I look for? What line?
I was hoping that somebody has seen this before and would recommend where to look to fix it. I have never seen anything like this on any phone.
Turn phone on, get one line through the apple logo across the screen. Then screen turns blue with lines all through it for a second before loading. Then when screen lock is on, tilt phone up for a second it blinks with blue screen with lines then normal home screen pops on. Like I said please view photos.
Please let me know.
There is also a ghost type issue
Cheers
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I’ve had this before and it was a problem with the screen, no matter how many times the connector is reseated it will still occur. I guarantee if you use a different screen the lines will disappear. Just make sure there isn’t any debris on the connectors and check to see if the connector is bent on the cable at all and straighten it out.
这个答案有帮助吗?
得分 1
1条评论:
Hi Luke, Thanks for the info. I'll try another screen again. Hope its that, would be an easy fix. I've had the Logic Board under the microscope and can't see anything bad. I've tried 3 screens so maybe the 4th will be lucky. Cheers
If anyone else has anything to add please do.
完成的
添加一条评论
添加你的答案
Tommy Duris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 63
