跳转到主内容
Model A1051 / 4 or 6 GB hard drive
iPod appears on iTunes for 1 second and then disappears
Hi everyone,
I recently purchased an iPod Mini 2nd generation off of ebay. The iPod itself works good. However, when I plug it into my computer, it is recognized for a few seconds and then disappears. I don’t believe this is an iTunes issue either, because it disappears in Finder as well.
This also isn’t an issue with my Mac either, as I connected it to my PC and the same exact problem happened. It appeared in iTunes and Windows explorer for a few seconds and then disappeared.
The “Do Not Disconnect” message appears on the screen for a few seconds as well before it disappears and reverts back to the main menu.
I opened it up and disconnected and reconnected the battery and hard drive, to no avail.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I have five of those cables, same result as listed above with all of them.
完成的
添加一条评论
1个答案
I believe the issue with this specific iPod is that the 30-pin connector on the Logic Board is damaged. While yes, it may charge, it probably doesn’t have the ability to sync data. I would suggest finding a cheap one on eBay and then replacing it yourself. (It’s actually quite a fun process!).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Conor Smyth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 444
