跳转到主内容
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
87 个问题 查看全部
iPad screen colours washed out
Hello,
The colours on my iPad’s screen appear washed out. All the colours work - but everything appears bleached. Sometimes the issue fixes itself and the screen goes back to normal, but after a minute or so of use it goes back to washed out colours.
I’ve attached a couple of photos to show what’s happening - a picture of the screen and the original photo to compare it against.
Not sure what’s causing it but fairly sure it’s a hardware issue as I did a reset all settings and complete DFU restore to hopefully rule out any software issues.
Any ideas for what’s going on?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello iscream,
this is a typical water (humidity) damage of your screen panel. Twice I had similar problem that turned out to be socket issue but most of that - circa 50 was flooded. By ice cream, kinder juice, breakfast cereal or some similar like “I just watched Netflix in the bath”. Not dived in a bath, toilet or see water.
You have got a screen assy for change, Air2 cost circa 90-110$ if you can change it by yourself. In a repair shop the cost increases to 180-200$
  • regards,
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
iscream 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 758
