跳转到主内容
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
149 个问题 查看全部
iPhone 11 pro stuck in recovery mode after trying to fix power button
I dropped my phone out of the car and it jammed in my power button, so when I got home I opened up my phone and tried to fix the power button. I wasn’t able to so I put it back together to find it in recovery mode. I have looked how to fix this, but nothing I have tried has worked. I tried to restore it with iTunes. I tried 3rd-party programs like iMyPhone and ReiBoot and they didn’t work. I need help trying to get my phone out of recovery mode.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
What error do you get with iTunes restore?
完成的
I don't get an error. It just pops up with the message that says "There is a problem with the iPhone "iPhone" that requires it to be updated or restored." When I restore or update it it shows the same message again.
完成的
M iPhone says the same, and there has not been any solutions
完成的
添加一条评论
2个答案
已选择的解决方案
hello Isaac,
the damage you are struggling with has nothing to do with a damaged button. Service mode is activated automatically when the integrity of the data flowing through the sensors is disturbed. The reason may be a short circuit in the logical installation, low-current data (not power supply) or broken connections between them. Take the phone to a good repair shop. It will be restored to the state it was in before the fall in 20-30 minutes. The cost should not exceed 120-150$
  • regards,
这个答案有帮助吗?
得分 2
添加一条评论
Actually if the power button is stuck and the iPhone is powered down it will display the "Connect to iTunes" error because the phone will automatically into recovery mode. That's how you get into recovery mode, by booting the iPhone and holding the power button. Apple should be a bit more clever and detect that the power button is constantly on, and offer to boot normally if the power button is constantly on.
这个答案有帮助吗?
得分 1
1条评论:
Exactly what Christian said, as long as the power button is jammed in you’ll have problems. Forget the complicated route. Start simple like getting the button unstuck then go from there. If you can’t do it take it to a reputable shop. If the damage that’s holding the power button in is bad you may need a replacement housing.
完成的
添加一条评论
添加你的答案
Isaac Nelson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 1,261
