跳转到主内容
加入维修社区 - 创建账户
Replaced battery - won't turn on
Model A1342. Old battery was swollen - MAC worked fine. But made me nervous. Bought new battery and installed. Everything went fine. Charged with MagSafe Orange then green + 2 hours at green. Nothing. No response to power button or any of SMC resets.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Let’s do this: Take the battery out, now with nothing connected press the power button for a good 15 secs. Now plug in the MagSafe the system should spontaneously start up, did it and is the MagSafe LED Amber or not lit at all?
这个答案有帮助吗?
得分 1
3条评论:
Did as suggested. Did NOT start up spontaneously. Light is green. Power button: no response. (Battery still out)
完成的
Is it possible that the old battery, which was swollen, damaged a component forcefully? I put the old battery back in and it also doesn't work now. (It worked before eI started disassembly but swelling made me nervous.)
完成的
FIXED! Last gasp attempt. Took out memory and replaced. Tightened all the screws I could see. Wiggled anything the battery might have pressed on. Did an SMC reset. (Said some prayers for patience.) and it started after about 10 seconds on the power button. Not a satisfactory fix but allows user to make sure everything is backed up. Thanks for your attention.
完成的
添加一条评论
The battery fault with New one
its sounds like the replacement battery may be faulty as the replacement supposed of charged so recommend contacting the seller and asked them for a replacement .
这个答案有帮助吗?
得分 0
1条评论:
See my other comment answer. Battery is apparently okay but old battery may have moved/damaged components. Fixed for now. I was going to return battery per your suggestion as last step. Thank you for your assistance and suggestion.
完成的
添加一条评论
添加你的答案
RICHARD BEYER 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 203
