跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Step 7-Back of camera changed picture/number - why?
The teardown Step 7 third picture yesterday showed a picture with three encoded numbers on the bottom of the camera module. The second number yesterday was 23XGDD. Today it is 31N07D. Did someone substitute the picture to mislead? Are you showing a part from a second teardown? If you still have a copy of yesterday's picture, did it have 32 pins?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
you're right - the first teardown was made with my "not that perfect" equipment - luke from ifixit got his 4s later than me and started the same thing, so some pictures have been replaced by better ones
and yes, it has 32 pins
这个答案有帮助吗?
得分 2
添加一条评论
have you figured out which cmos sensor is being used? Omnivision/Sony?
这个答案有帮助吗?
得分 0
1条评论:
no, i didn't ! i guess that the ifixit crew will dig up this information soon
完成的
添加一条评论
添加你的答案
Dick Evans 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 495
