跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Ambient light sensor not working
Hi there, I have an iPhone 8 Plus which I have replaced the screen on and I am having issues with the light sensor. I have replaced the original proximity as the original broke. The screen will light up and full brightness when using the original however when using the new one the brightness is at its lowest every time I pick the phone up/press the power button. I used a 3rd proximity which does the exact same as the 2nd. The phone is ios 14. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What ios version are you running?
完成的
iOS 14.1 to be precise
完成的
添加一条评论
1个答案
hello there,
if replaced flex does’t work, it is means that is a Chines category C or D (I assume that the phone has no fault - which is also easy to check). If you have a magnifying glass or a second iPhone with new firmware (there is a magnifier program there) look at the sensor at the end of the tape. It is probably stuck with glue instead of soldered (if it is there at all). This is a common cheat (or oversight) of the Chinese people assembling the tape. Maybe a dishonest seller sold you a damaged tape - you can often buy cut or torn tapes with missing connectors etc on ebay.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rileytucker2211 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 189
