跳转到主内容
Released April 2015, also known by model name A10-70F ( 'F' representing that this is a wifi only model).
Shuts down and reboots randomly, when in use!
Shuts down when in use !!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
This sounds like a software problem but idk
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Things to try to resolve the problem:
a). Wipe the cache partition and check if this resolves the problem
b). Try starting the tablet in safe mode and check if the problem still occurs or not.
Being random makes it difficult so you may have to use it in this mode for a while to make sure that it doesn't occur.
If it doesn’t happen at all when in safe mode, then a downloaded app is the cause of the problem. The trick is to find out which one is the culprit. You will need to uninstall each downloaded app, one by one and operate the tablet in normal mode between each uninstall. When the tablet works OK in normal mode then the last downloaded app that was uninstalled was the cause of the problem
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
JOHN PARRY 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 1,545
