跳转到主内容
The LG 60LM6450 is a 60-inch LED television released in 2012. It supports 3D video with glasses at a resolution of 1920x1080 pixels.
77 个问题 查看全部
Why does my tv turn black after 10 minute
So basically my television turns black after around 10 minutes of usage you can still hear noise and everything I’ve seen people saying it’s a backlighting problem and I want to know if there is anything that I could do at home to fix it I can see things in the background when using it but it’s barely visible if at all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @lakika14 ,
You may be able to see the images on the screen better if you shine a torch at an angle close to the screen. Trying this in a darkened room will also help as they will be very faint even when using a torch.
If you have a LG 60LM6450 TV here is the service manual that may help you to find the problem
Here’s the No video / normal audio troubleshooting flowchart which may be a good place to start with, when the problem occurs
Here is the section that shows the power board voltages.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lakika 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 27
