跳转到主内容
加入维修社区 - 创建账户
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Auto brightness stopped working
I had replaced the entire front camera assembly recently with a cheap part. I don’t know if that was the reason, but the auto brightness is no more working. The proximity sensor too wasn’t working, but after pulling them out and fitting them back, I got this one working, but the auto brightness is not there to be seen as well as the setting is missing under Display & Text, though a search can still find it.
Should I replace the front camera full cable with a costlier part or is it something simpler?
Help appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You might need a new part, but try this:
Get to the ‘slide to power off’ screen.
Press and hold the home button. DO NOT keep holding power. DO NOT slide to unlock.
这个答案有帮助吗?
得分 1
1条评论:
It sort of reset something as it went back to unlock screen, but putting the brightness slider all the way up didn't move it back down in full light conditions. Also, I didn't find the 'Auto brightness' setting in the phone anywhere.
完成的
添加一条评论
添加你的答案
Vijay Kanta 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 85
