跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
Is 2nd. Gen back panel interchangeable with 3rd. Gen?
Hello,
I have a 32 GB 2nd Gen Touch and the insides are basically shot. However, there is engraving on the back panel that I would like to save. Will the 2nd. Gen back panel fit on a 3rd. Gen. I thought since I have to replace all the internal components I might as well update them as much as possible. Would like to use a 64 GB 3rd. Gen if possible. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I don’t know off hand, but i would look at the measurements of both panels, and see if they are the same. Even so, do this repair at your own risk.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the reply. The information I have gathered thus far says the sizes are the same. My real concern is whether the stand off for the screws that hold the boards/controls in place are in the same location. In this case, the reward is worth the risk.
完成的
添加一条评论
添加你的答案
David Rawson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 10
总计 58
