跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
internal display only works when an external display is connected
the internal display only works when a external via HDMI is connected, at that time both internal and external work perfectly, disconnect external and nothing but garbled horizontal lines, replaced logic board and display with no positive result still same symptoms
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It was the LCD after all , I originally tried what was supposed to be a known Good lcd and then was unsure after symptoms did not change.
这个答案有帮助吗?
得分 0
添加一条评论
Your logic board has a problem somewhere within the video logic. What you are seeing is the loading of HDMI port appears to act as a signal load as the internal one has failed.
Someone with good board diagnostic & micro soldering should be able to fix your logic board. Otherwise you’ll need a new logic board.
这个答案有帮助吗?
得分 0
7条评论:
I thought the same thing at the beginning but after REPLACING the logic board as I mentioned the problem is unchanged, I also replaced the retina Display and nothing changed, the only thing that i have not changed is the daughter board
完成的
@appleheadrepair - I'm wondering if you have a bad ground. What happens when your system is not connected to the MacSafe charger is that acting differently?
完成的
same exact result already checked that and swapped ssd to rule out any Apple OS X quirks, something happens when the hdmi port requests connection . This is very odd situation .
完成的
I will check the I/O (daughterboard) in the morning and see if there is possibly some kind of foreign debris in the hdmi port or damage there, but then its highly unlikely to be the culprit. Just plugging in the hdmi cable does nothing, it has to complete the connection and see the extra display, which originally I was sure meant the GPU switching got messed up but a complete replacement board same exact symptoms ??
完成的
@appleheadrepair - The I/O cable ??
完成的
显示更多的2条评论
添加一条评论
添加你的答案
appleheadrepair 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 128
