跳转到主内容
加入维修社区 - 创建账户
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
3rd time display failure
I have a display problem here.
It’s been sent three times to Apple technical support and my problem still continue, Apple technical support tells me problem is a software problem!
Has anybody saw this problem before?
thanks your comment
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sadly, its time to visit the Apple Store (not an authorized reseller) one more time! This time with your service paperwork in hand, talk with the service manger that you need your system fixed, and this is NOT a software issue its a problem with this given system and you want a replacement.
They will likely say No! But don’t give up! Speak with the store manager and then the regional managers (Service and retail).
If you don’t have an Apple Store near you you’ll need to call Apple and have your issue escalated. Don’t accept No! Keep pushing.
You also need to clean your system! A dirty system says you don’t treat it as a valuable item to you. And the person servicing your system we care less! Which you don’t want.
As to why your screen is failing. It’s likely overheating! I would install a good thermal monitoring app to watch things. I use TG Pro as it offers what you need.
Make sure you don’t block the vents on the side and back as not air flow will do you in! You will want to see if what you are running (doing) is pushing your system too hard. Apple (and Intel) did you a disservice with the design of this system as the CPU runs hot! And the location of the T-CON logic is too close to the heat so it gets cooked!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
can İnce 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 89
