跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
577 个问题 查看全部
no connection or charge, but reboot when powered down
my iPad Air does not connect to a pc via original apple cable. It does not charge when put in an outlet, but when i power it down while hanging on the charger, it reboots so it must recognize something?
the screw is tight, i tried that already.
anyone got a clue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello Niels,
what screw you talking about? Who told you this?
seriously now, your problem is related to damage to the charging port (flex behind a port) or the electronics in the charging circuit. Unfortunately, this still happens with ipdads. Either way, it requires expert diagnosis, skill and experience. If you know some about re-work of electronics you can repair it at home, if not, don’t do this yourself. Ipad is often damaged when attempted to repair by people with poor knowledge and poor experience (there are many of these in street workshops). Think about it when you take your tablet anywhere. Find a specialist, talk to him first. It will surely explain the problem to you, on the other hand - very simple and easy to fix.
  • regards,
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Niels Van Osch 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 16
