跳转到主内容
加入维修社区 - 创建账户
苹果 iPad Air 的纯 Wi-Fi 版本,型号为 A1474。有深空灰或银色可选,配备定制的 A7 处理器,存储容量有 16、32、64 和 128 GB 可选。
Stuck in a reboot loop I think?
So when I plug my iPad air 1 in, it goes to Apple logo then goes black, and just does this over and over. I hold power and home and it just does the same, sometimes goes into dfu mode when im holding home and power. Well you'd think I should plug into iTunes. Well sad thing with that is, it won't even power on or enter the loop or go into dfu mode when plugged into PC. Hopefully someone out there knows what to do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello Benjamin,
it looks like an internal problem after unauthorized repair (quite a common case). iPads are sensitive to the lack of knowledge of technicians, which is why not many of us can work with them. If you fail to complete the restore process from DFU, please find a good repair shop. It will need knowledge and equipment to repair that I suppose you don't have.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Benjamin Sharp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 238
