跳转到主内容
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
160 个问题 查看全部
Why is my display making my room lights flicker?
My Thunderbolt Display recently began making a buzzzing noise. The buzzing starts soon after it’s plugged into my MacBook Pro 2019 ( but not immediately) then after about 3 minuets (sometimes longer) the lights in my room begin to flicker. As soon as I disconnect it from my computer, and the screen goes blank, the buzzing stops and the lights stop flickering. I’ve tried plunging the Display directly into the wall, vs the power strip, into different wall receptacles, and into different ports on my laptop, no change. Also, this did start after updating my laptop to macOS 11 Big Sur. Lastly, I’m running three 27” Thunderbolt Displays and this is only happening to one of them. Thank you in advance.
Update (11/17/2020)
After doing some reading, I'd like to add, decreasing the screen brightness lowers the noise and I'm not using the Display to charge my MacBook and there is nothing else plugged into the Display via USB etc...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I think you are facing a power issue within your buildings wiring! You’ll need to get a AC outlet tester 3-Wire Receptacle Tester here’s more on why A MUST HAVE TOOL - The Electrical Outlet Tester - How to use and why you should have it I’m suspecting you have a hot ground!
The other possibility is the Thunderbolt display power supply has a short to ground.
这个答案有帮助吗?
得分 0
2条评论:
Thanks Dan. However, due to this happening when plugged into different wall receptacles, AND the other two monitors aren't making the lights flicker, narrows it down to the one monitor and not the wiring. But, to be sure I did test all my receptacles with my Receptacle Tester and they are wired correctly. Now, question is what component on the Display is causing this? Power Supply, Power Cord, Thunderbolt Cord...? BTW, this issue didn't present itself during 10 hrs of use yesterday. Thanks again.
完成的
@oikanamas - That points to a power supply is failing.
完成的
添加一条评论
添加你的答案
David Meyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 98
