跳转到主内容
加入维修社区 - 创建账户
KitchenAid Artisan 系列 5 夸脱抬头式厨师机,型号 KSM150PSER。所有以 KSM150PS 开头的型号均为同一设备,仅颜色不同。
Wire whisk stuck on
The wire whisk is stuck on the rotator shaft. I’ve turned it up and to the left but it’s not coming off. Also not sure if the rotator should be moving but it does in its planetary way while trying to remove it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If the planetary is moving something has probably failed inside the gearing mechanism. You should be able to grip the drive shaft with needle nose pliers and remove the whisk easily. Keep in mind that it has to slide upwards slightly to disengage from the “bayonet pin” on the drive shaft though. Make sure you unplug at outlet before attempting!
这个答案有帮助吗?
得分 1
2条评论:
Thank you. I think i need to return it then as its only a week old and the rotary keeps moving as I try and remove it. thank you.
由完成的
Actually, I had put some vegetable oil on it with a tip and still couldn't get it off but I managed to do it with the pliers so maybe i don't need to send it back....thank you.
由完成的
添加一条评论
添加你的答案
wendy macdonald 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 16
总计 558
