跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Did they REALLY fix the "Antennagate" issues?
Did the new iPhone 4S resolve the issues with holding the phone on the bottom corner? My iPhone 4 absolutely goes from 4 - 1 bar when touching the bottom corner. I HOPE a case is not "Suggested" for correcting this with the new 4S.
Thanks!!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Apple insists that the issue is fixed by switching between two antennas (still the steel bezel around the case) to maximize call reception. How well this works is still a mystery. We'll have to wait and find out when full reviews come out, but from our teardown we cannot determine the answer.
Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
Apple has not spoken on the issue.
During the keynote, they mentioned that they had a revolutionary antenna design-- dual anntenae, but the phone is a dual-gsm-cdma phone, requiring two antennas. In a world phone situation, the phone would switch between the two antennas frequently. This is what they've spoke about.
这个答案有帮助吗?
得分 0
添加一条评论
I currently own a 4S and it seems the 'antenna-gate' issue has been resolved. Although, like most smartphones, you may lose a slightest bit of reception but because of the new "antenna switching" method, it's not enough to reflect on the signal bars.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Underwood 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,104
