跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
In Step 10 what is the hole next to the Proximity Sensor
It looks like there is a hole through the front part of the case in Step 10. Right above where the front camera and the earpiece meet. What is it? Status LED? Proximity sensor?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
The proximity sensor and Ambient light sensor are next to each other and there is an oval window to the world for them. There is another hole right next to them that I am wondering about
完成的
添加一条评论
2个答案
已选择的解决方案
there is an infrared emitting device next to the proximity sensor
it's active as soon as the screen light goes on.
这个答案有帮助吗?
得分 0
1条评论:
the IR emmitter is part of the proximity sensor. Its next to the ambient light sensor. I am trying to figure out the hole next to those...perfectly round that was not on the previous phones.
完成的
添加一条评论
Ended up tearing the iphone apart and found that they have a new Proximity sensor design in the 4S. It takes up all the space that the proximity sensor and ambient light sensor used in the iphone 4. The Ambient Light sensor is now moved over and that is what uses the little round hole. Interestingly enough they actually painted the window on the white 4S.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Barry Gilbert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 970
