跳转到主内容
The HP Elite x2 1012 G1 is a tablet with an included keyboard and stylus pen. The HP Elite x2 comes with Windows 10 Pro, an Intel Core m3 processor and a 4GB hard drive.
What is the problem with an impaired touch screen?
Hello,
My laptop fails to response to touch input, in short, no touch at all while the display works fine.
I wonder if it is the problem with the screen itself or from some part called Touch Control Board.
Many thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If your touchscreen isn’t working or not responsive how you would expect, first thing is to try restarting your PC. If you’re still having problems, check for updates:
  1. Select Start , then select Settings .
  2. In Settings, select Update & security , then WindowsUpdate , and then select the Check for updates button. Install any available updates and restart your PC if required.
  3. If you didn’t have any updates that required a restart, it’s still a good idea to restart your device to make sure any pending updates are installed.
I hope my answer comes in handy for you.
这个答案有帮助吗?
得分 1
2条评论:
Thank you for your reply,
It seems that the problem doesn't come from any software defect. I have tried both updating and restarting the system but nothing changes.
My question is, in case it is a hardware failure then which part of the device should hold responsibility and requires replacement.
完成的
@noriserif If it is a haraware failure, the touch glass or touch chip could be the problem, that way you'll have to replace the screen itself. Before that, make sure all the cables sit tightly.
完成的
添加一条评论
Hi @noriserif ,
Try the procedure shown under “UPDATE 30/09/2016” in the Chosen Solution in this link.
How to reinstall touch screen driver? My touch screen stopped working.
Worth a try anyway as it has helped others with the no touchscreen problem in HP laptops.
What is the full model number of the laptop?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nori 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 33
总计 1,936
