跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Does the new iPhone 4S have a SIM Card easily accessible/removable?
I've asked each carrier ATT and Verizon, as well as the Apple store - nobody seems to have any answers.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thanks! Does that mean I will have the option of using local carriers globally? - that seems to be the big question. Correct me if wrong, otherwise the options seem limited to jailbreaking, purchasing an expensive "unlocked" phone or paying for the global plan provided by the carrier.
完成的
添加一条评论
3个答案
已选择的解决方案
Yup! The 4S has a microSIM slot right on the side, just as the AT&T iPhone 4 did.
这个答案有帮助吗?
得分 1
添加一条评论
Does this mean if I go to another GSM country, I could have their SIM card installed for in that country local calls and Internet?
这个答案有帮助吗?
得分 0
1条评论:
Ya, you should be able to. Here's an article about it if you wanna check it out.
完成的
添加一条评论
It needs to be unlocked for you to use in other countries. If I remember, Sprint and/or Verizon will unlock for you after a certain time with them.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Montana Pup 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 12,049
