跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
351 个问题 查看全部
Screen jumping, glitching after installation
Replaced iPhone 11 screen but the screen is jumping and glitches after screen replacement. Had similar issue with the cracked screen so I don’t know if there was a previous issue not related to the screen. Anyone have a similar problem? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
I can’t say I’ve had this problem before but it could be that the replacement display is also faulty. Did you unplug the battery prior to removing and reconnecting the display? I would leave it turned on for a couple of hours and see if the problem goes away, it could just be static.
这个答案有帮助吗?
得分 0
2条评论:
Yes, I unplugged the battery. I’ve had a similar issue and agree with you that it could be a faulty screen. I’ll reach out to the ifixit team for help since I purchased it from them
完成的
Yes either a faulty screen or just some static, try leaving the phone turned on for a while and see if the problems carries on. If the problem continues then it sounds like a faulty digitiser.
完成的
添加一条评论
添加你的答案
David Torres 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 23
总计 676
