How to check if screen replacement part is original
I bought a screen replacement for the Pixel 4 XL (OLED panel + digitalizer): seller says it’s original OEM, how can I check if this is true and it’s not a compatible 3rd party part of low quality?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 112
where did you buy the parts from? Is it a screen all on its own or is it attached to a frame?
由 Jesse Hooton 完成的
https://www.ebay.it/itm/GOOGLE-PIXEL-4XL...
I also have some real pictures, not sure how I can send them here, maybe by email?
由 Giovanni Stoto 完成的
There used to be the manufacture and a linking number on the pixel 3 and earlier display. Samsung manufactured the Pixel 4/4 XL display. Can you see any text or labelled companies on the display/display flex. Otherwise try connecting the display and observing the quality, especially against your old, I assume cracked, original display. Hope this helps (:
由 TmG 完成的
